January 30, 2012, 17:05 |
inlet turbulence in LES (FLUENT)
Rep Power: 15 |
I am intending to use LES in FLUENT. I am using pressure based coupled solver with air as the working medium and assigning ideal gas properties. Since the flow is not incompressible, I cannot use velocity inlet boundary condition and hence the inlet turbulence generating techniques in FLUENT. This page says (at the bottom) for all other boundary types apart from velocity inlet the flow is assumed as laminar in LES calculations. http://www.aeromech.usyd.edu.au/AMME...ug/node470.htm Yes, I can increase the inlet length but I dont want to try it because of obvious reason (computation cost). Is there any alternative way to generate synthetic inlet turbulence (by hooking a UDF) with pressure inlet BC. If yes please explain or direct me to suitable references. Thanks |
November 18, 2012, 05:15 |
Ebrahim
Rep Power: 16 |
Hi dynamics,
I have the same problem. I want to use vortex method perturbation for pressure inlet BC! couldn't you find a solution for this problem? Regards, Ebrahim |
November 18, 2012, 14:55 |
Ebrahim
Rep Power: 16 |
Hi sbaffini
You are right. your comment helped me very much. Thank you |
April 6, 2014, 16:17 |
Rep Power: 15 |
It was not available in Fluent 6.3 which I was using while posting the question.
Display Modes | |
Inlet BC for LES | sek | OpenFOAM Running, Solving & CFD | 101 | April 16, 2013 19:04 |
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure | jola | FLUENT | 1 | May 5, 2011 14:33 |
LES in Fluent | littlelz | FLUENT | 0 | April 4, 2011 07:32 |
Inlet turbulence generation for LES | Sungho Yoon | CFX | 2 | November 4, 2008 09:09 |
