How to set Solution Initialization in transient
Dear all.
I am simulating a tank filling case in transient model, the inlet is downside, and fill in tank under the pressure--40Kpa. The pressure in the tank is 20KPa. How should I set the Solution Initialization? Set the "Gauge Pressure" as 20KPa or set the velocity in directly? Thank u in advance. |
you could initialise it in the standard way, then patch the pressures to particular regions
Dear mebll10,
"initialise it in the standard way", U mean initialise it with default setting? or can initialise "from inlet"? Thank U. Best Regards. Jason |
