June 19, 2010, 01:04 |
modeling gas expansion
hi, this is the first time I use FLUENT because I need to simulate a gas jet coming out of a very small nozzle into vacuum. e.g. the density profile or pressure distribution (not the flow inside the nozzle). Assuming I know the mass flow rate at the nozzle tip.
It seems to be a not so tricky problem but I just can't make the correct boundary conditions or models to get convergence or physical results. Can anyone please help and give me some suggestions? I'll be very appreciative. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Modeling Heat Generated by Gas Flame (CFDesign) | Ross Fotheringham | Autodesk Simulation CFD | 2 | October 30, 2007 11:25 |
Dense gas dispersion modeling | Alberto | Siemens | 1 | October 3, 2006 16:03 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
gas expansion in pipe crack propagation | Marco Evangelos Biancolini | Main CFD Forum | 2 | October 4, 2000 10:41 |
