-   -   how to simulate the rotation of a solid part (http://www.cfd-online.com/Forums/fluent/77694-how-simulate-rotation-solid-part.html)
Jiuan June 30, 2010 22:51
Dear All,
I want to model a heat transfer problem with the rotation of a solid part. The shape of the rotating solid part is a surface of revolution.This rotating solid part contacts with another stationary solid part. Does anybody have an idea how to do that? Thanks a lot.
jack1980 July 8, 2010 10:00
Perhaps you can give the object a 'wall' boundary type, and then specify as moving wall. Make sure to set the correct center/axis of rotation.
dobiarz July 10, 2010 02:54
I think you should use MRF (Multiple-Reference Frame Model) or SMM(Sliding Mesh Mode). SMM is for more complicated model. See presentation below:
http://www.sendspace.pl/file/ac84e64e497c1b67e353c0d
