how to simulate the rotation of a solid part
Old   June 30, 2010, 22:51
Default how to simulate the rotation of a solid part
Dongzi Wei
Jiuan is on a distinguished road
Dear All,
I want to model a heat transfer problem with the rotation of a solid part. The shape of the rotating solid part is a surface of revolution.This rotating solid part contacts with another stationary solid part. Does anybody have an idea how to do that? Thanks a lot.
Jiuan is offline   Reply With Quote
Old   July 8, 2010, 10:00
Jouke de Baar
jack1980 is on a distinguished road
Perhaps you can give the object a 'wall' boundary type, and then specify as moving wall. Make sure to set the correct center/axis of rotation.
jack1980 is offline   Reply With Quote
Old   July 10, 2010, 02:54
dobiarz is on a distinguished road
I think you should use MRF (Multiple-Reference Frame Model) or SMM(Sliding Mesh Mode). SMM is for more complicated model. See presentation below:
http://www.sendspace.pl/file/ac84e64e497c1b67e353c0d
dobiarz is offline   Reply With Quote
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 11:13
how to simulate 2d solid heat conduction using CFX richard CFX 3 March 24, 2008 07:27
Can I simulate multicomponent flow in porous solid galary FLUENT 0 May 21, 2006 00:53
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 11:41
rotation of solid domain manohar FLUENT 1 July 22, 2005 13:34
