write journal file
Old   July 5, 2010, 05:06
Default write journal file
bob12 is on a distinguished road
hi
how can i write a journal file from fluent?
thank you
bob12 is offline   Reply With Quote
Old   July 6, 2010, 02:08
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
basically you can use text command...
; Read case file
rc example.cas
; Initialize the solution
/solve/initialize/initialize-flow
; Calculate 50 iteration
sit 50
; Write data file
wd example50.dat
; Calculate another 50 iterations
it 50
; Write another data file
wd example100.dat
; Exit FLUENT
exit
yes
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 6, 2010, 03:08
but there is a command that write journal file from an exist simulation?
i have read to fluent's manual and it explain to use write journal file and then stop journal file.
so i thinking that fluent recorder the next operation; is it?
Old   July 6, 2010, 03:26
-mAx-'s Avatar
Maxime Perelli
you can create a journal file from Fluent:
before setting your case, go to file/write/start journal...
Then set up your case, once you are finished, go to file/write/stop journal...
Fluent should write everything you did in a journal file, which you can now read and reproduce.
hope it helps
Old   July 6, 2010, 03:43
thank you very much
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
Problem with Boundary Conditions using a journal file T.S. FLUENT 3 July 27, 2009 08:31
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 07:25
