Home > Forums > FLUENT
perforated plane
Old   July 3, 2010, 06:03
Default perforated plane
chen sam
samerexe is on a distinguished road
if I want to simulate a 2D plane which has holes.
I try to build a model which has holes in Gambit.
But,this method is not good.
My question is porous jump is a sound-absorbing media or only a plane which
has holes?
Porous jump can replace the steps which build model in Gambit?
Thank you
samerexe is offline   Reply With Quote
Old   July 5, 2010, 02:20
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
what is your problem in Gambit?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 5, 2010, 11:51
Susan
hvem10 is on a distinguished road
You can use the porous jump instead of your perforated plate. You just specify it as porous jump in gambit and then you can set the correct reistance in fluent
hvem10 is offline   Reply With Quote
Old   August 28, 2010, 17:33
Rupak
rupakbanerjee is on a distinguished road
how do i specify a region as a porous jump in Gambit?
rupakbanerjee is offline   Reply With Quote
Old   August 30, 2010, 07:31
Byron Smith R J
byronsmith is on a distinguished road
hai
porous jump is available as a boundary condition in fluent BC options
byronsmith is offline   Reply With Quote
Old   September 14, 2010, 03:06
-mAx-'s Avatar
Maxime Perelli
if you try to find the pressure loss from your perforated plate, I don't think using porous jump is the right choice, since you give the resistance of the plane as input...
Thread Tools
Trackbacks are On
Problem with Gmsh nishant_hull Open Source Meshers: Gmsh, Netgen, CGNS, ... 23 August 5, 2015 02:09
boundaries with gmshToFoam‏ ouafa Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 May 21, 2010 12:43
Modeling thin perforated plates as porous media Mike FLUENT 0 August 21, 2007 04:16
ICEM and symmetry plane Roland CFX 3 September 13, 2006 08:38
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 08:16
