Home > Forums > FLUENT
MIcrochannels.
Old   July 4, 2010, 14:01
Default MIcrochannels.
Amir
abadiee is on a distinguished road
Send a message via Skype™ to abadiee
I am simulating microchannels in FLUENT. I have a single channels with rectangular crosssection. Hydrolic diameter is 0.0015, Length is 1 cm.
BC: Inlet> Velocity inlet
Outlet> Outflow
Bottom wall > Heat flux: 100000 w/m2, Th:0.0005m
Upper and side walls: Adiabatic, Th:0.0005m
But What I get in pressure contour is negative pressure inside the channel which does not make any sense.
Can I have your opinions on the issue please.
abadiee is offline   Reply With Quote
Old   July 4, 2010, 15:19
karine
thecfduser is on a distinguished road
Hi
the pressure in the N.S equation appears as a gradient. What is important, in an incompressible flow, is the pressure difference and not the pressure.
The pressure will depend on the point in wich u choose the reference pressure (in operating pressure window of Fluent).
Anyway, i think ure simulation is not well posed.
Choose pressure outlet instead of outflow, with pressure=0 on that boundary.
U will get positive pressure inside the microchannel, and ure simulation will be good.
thecfduser is offline   Reply With Quote
Old   July 4, 2010, 16:10
Amir
Thank you.
The problem with pressure outlet is that the fluid is not going to atmosphere pressure. It is in a closed circle and I choose outflow to see how much the outlet pressure is. When I choose pressure outlet with 0 Pascal. the outlet pressure is 0 which is not sensible. Even I changed the operation condition but no changed in negative pressure. The gradient is absolutely correct but how can I have the absolute pressure?
Old   July 4, 2010, 16:30
karine
With outflow, u assume that ure fluid tempearture dont change anymore at the outlet...(dT/dx=0)....
When u put outlet pressure with 0 Pa, it is the gauge pressure that is 0. To get the absolute pressure, u must know the pressure at least in a point of ure domain (the pressure biggest derivative is 1st order in NS equations).
so in a resume, if u dont know the absolute pressure in a point of ure domain, u cannot get the absolute pressure at ure outlet.
(if u choose a pressure outlet, Fluent will not consider anymore the operating condition. The operating pressure will be calculated from ure outlet).
If u didnt undertsand, write to me again
Thread Tools
Trackbacks are On
Problem simulating bubble formation in microchannels iitian2005 FLUENT 0 June 3, 2009 03:03
How to model H2 flow through microchannels? Adarsh Main CFD Forum 3 December 15, 2005 12:47
MR Fluid Flow through microchannels Sinan FLUENT 0 September 18, 2004 00:03
Two-phase flow in microchannels Shubidu Main CFD Forum 0 January 5, 2004 06:24
secondary flow in microchannels uwe Main CFD Forum 1 August 26, 2001 11:35
