write journal file
hi
how can i write a journal file from fluent? thank you |
basically you can use text command...
; Read case file rc example.cas ; Initialize the solution /solve/initialize/initialize-flow ; Calculate 50 iteration sit 50 ; Write data file wd example50.dat ; Calculate another 50 iterations it 50 ; Write another data file wd example100.dat ; Exit FLUENT exit yes |
but there is a command that write journal file from an exist simulation?
i have read to fluent's manual and it explain to use write journal file and then stop journal file. so i thinking that fluent recorder the next operation; is it? |
you can create a journal file from Fluent:
before setting your case, go to file/write/start journal... Then set up your case, once you are finished, go to file/write/stop journal... Fluent should write everything you did in a journal file, which you can now read and reproduce. hope it helps |
thank you very much
