Does the wall BC set k & e to zero?
Old   May 8, 2006, 05:30
Default Does the wall BC set k & e to zero?
Lucy
Hi,all!
I use the ske model and set the BC as "WALL" for some solid boundarys. But after caculation I ploted turbulence kinetic energy(k) along these "walls" and found them not equal to 0. Why???
I tried adding some source terms to the momentum equations, but the caculations diverged soon. I checked the values of k and found them quite large somewhere on the wall. I think this resulted in the divergence.
Can anyone tell me how fluent set the "WALL" BC? If I change the boundary condition "wall" to "velocity inlet" and set velocity,k and e to 0, is there any problem?
Any help will be very appreciated!
Old   May 8, 2006, 12:39
Default Re: Does the wall BC set k & e to zero?
Evan Rosenbaum
The default boundary condition for a wall is no-slip, so the immediately adjacent velocity is 0. Maybe if you set the walls to be slip walls (in the wall boundary condition panel) you would get nonzero k and e.
Old   May 8, 2006, 21:53
Lucy
The problem is that I want k and e on the wall to be equal to ZERO but FLUENT actually don't set them to zeros in the default WALL boundary condition.
Old   December 10, 2010, 11:49
Marta's Avatar
Marta Lazzarin
Marta is on a distinguished road
Hi guys!
I am trying to create a boundary condition in Fluent similar to the wall+source which can be found in CFX.
Do you know if it's possible for me to use any kind of udf to do this?
In particular what I would like to do is to add a mass flow rate source, instead of using the mass flow inlet boundary.
This is because i need to perform some other operations which are only allowed on walls.
Thanks a lot in advance!
Marta
Marta is offline   Reply With Quote
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 11:49
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
how to set up wall function in bubbleFoam adouchihiitoko OpenFOAM Running, Solving & CFD 5 November 5, 2010 05:59
Parallel implementation of k-e model Niels Main CFD Forum 6 June 27, 2008 14:31
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
