Fire simulation in a enclosure
Hello Everyone,,
I am trying to simulate a fire inside a close chamber. but i am not understanding what should be the enclosure material it should be?? because incase of a real house it is wall...so is it possible to apply wall(cement+briack+..) for fluent simulation? or what else is acceptable and realistic ??? Thank you |
fire simulation using fluent
hii everybody
i want to ask how i can make or generate a fire in closed volume using fluent ? is Fluent able to make simulation for fire or not? |
Yes you can. you can either use combustion model or you may apply a fixed heat source to produce fire best of luck |
