UDF Problem!
Old   July 15, 2010, 04:26
Default UDF Problem!
Andrè Hüllmann
huela is on a distinguished road
I have a problem with my udf. I want if the Pressure falls under 0 that the value of Pressure would be set 0.
#include <udf.h>
DEFINE_ON_DEMAND(hallo)
Domain *d;
real patm = 101325.0;
real pmin = 0.0;
real pressure = 0;
Thread *t;
cell_t c;
d = Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
pressure = C_P(c,t);
if (pressure < 0.)
pressure = 0.0;
end_c_loop(c,t)
begin_c_loop(c,t)
C_UDMI(c,t,0) = pressure;
end_c_loop(c,t)
Thank you for help!!
huela is offline   Reply With Quote
Old   July 15, 2010, 05:40
Max
coglione is on a distinguished road
DEFINE_PROFILE() is the way to go to fix a flow variable to a certain value for any cell in your grid.
Have a look at the UDF-Userguid section 2.3.15, there is also an example that might be helpful.
BTW, what is the reason for your intention to prevent negative pressure values? If it seems to you that this is unphysical, keep in mind that in Fluent pressures are always defined as gauge pressure to an operating pressure defined by you and static pressure may drop significantly for high speed flows and may become negative which does not necessarily mean that your solution is wrong.
cheers
coglione is offline   Reply With Quote
Old   July 15, 2010, 15:32
Steven Qhin
chaozhong.qin is on a distinguished road
I found a small mistake in your UDF, as follows:
begin_c_loop(c,t)
if (pressure < 0.)
pressure = 0.0;
(note that: C_P(c,t) = pressure;
return the value to C_P(c,t)
end_c_loop(c,t)
chaozhong.qin is offline   Reply With Quote
Old   July 23, 2010, 03:20
Andrè Hüllmann
Thank you for answer!
But what I have to change in my UDF?
Thank you!
Old   May 8, 2015, 19:02
sozen is on a distinguished road
Thank you!
Could you solve the problem?
sozen is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
