January 28, 2009, 10:23 |
Problem in tutorial 12
I'm working on Tutorial #12 from the Fluent CD, and I can't go on after loading the UDF valve.c because this message keeps appearing:
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: () Does anyone knows what I might be doing wrong??? Thanks! |
January 28, 2009, 11:18 |
Re: Problem in tutorial 12
Hello
Is this the first time you've used a UDF? On windows machines you need to launch fluent from the command prompt if you are using UDFs. (Under Programs -> Fluent Inc there should be Set Environment, after clicking on this you can launch Fluent by typing fluent, (perhaps followed by 2d/3d/2ddp etc.) into the command prompt, from any directory). Otherwise are there any errors above that in the compilation? This also would stop the library from being loaded. Does this help? Kris |
January 29, 2009, 00:09 |
if u want to load the library, you must install a C language compiler first and set the environment as instructed.
January 29, 2009, 08:11 |
diesel problem
sir,
How to model diesel engie in gambit.suggest me some examples.If you have any problems please send me.waiting for your valuable reply. Thank you. |
January 30, 2009, 10:37 |
well, after doing all you said, I'm still getting the same error....
and there are no more errors above the compilation. Thanks anyway! |
January 30, 2009, 11:11 |
Hello again
Does Fluent build a folder in your working directory called libudf containing scr and ntx86 folders? scr should have the a copy of the .c files you compiled from your working directory. I had some problems creating the library on a 64bit machine as Fluent wanted to put the makefile etc. in a different folder. Cheers. Kris |
January 30, 2009, 11:14 |
yes, the scr and ntx86 folders are created. scr has the copy of the .c file.... but still nothing.
thanks! |
February 2, 2009, 06:54 |
if u wanna use UDF u should have visual studio (SDK).and while opening dont keep the folder in desktop
July 18, 2010, 13:59 |
#9 |
Dave Smith
Rep Power: 15 |
Hi
Did anyone get the UDF to load, I can build the file valve.c, but when I click on load it gives errors and then I cant hoook the function. Can anyone please help with the matter, I have MS visual studio 2008 installed and am using fluent in win xp 32bit. Does anyone know why this is not working when asked to load? Please help Thanks in advance |
Display Modes | |
XiFOAM tutorial Problem | 21kalee | OpenFOAM Running, Solving & CFD | 0 | April 22, 2008 18:18 |
Problem of CFX tutorial 13 | Susan | CFX | 2 | January 2, 2008 02:34 |
Problem with icoDyMFoam tutorial | matlie | OpenFOAM Bugs | 10 | April 26, 2007 04:51 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
Problem in Tutorial 11 | Leon | Siemens | 5 | December 20, 2006 06:06 |
