Surface points
I can't create any surface points in my domain. I tried everywhere and it won't work. What should I do ?? Plz help. Thanks !!:( |
I thought you got it all taken care of here. What specifically is the problem?
That was the problem of inputting them with less time.
Now, I could input them easily but fluent won't accept the points. It says "surface creation failed ocject #F" For one case, only a few poitns were refused but for another one, fluent won't accept any of the points. The coordinates are right because they worked fine in Workbench. Any suggestions ?? |
It seems like this error occurs when you attempt to create a point that is outside of the solution domain. Have you made sure that the units of coordinates of the point match those of the solution?
Thanks !
it seems like I had several problems. First, my units were in mm and FLuent was set in m. Another thing was that I had to shift the points about 0.1mm from the actual place to not interfere with the boundary... Thnaks again :-) |
