July 20, 2010, 12:32 |
Particle tracks - exported file size
Patrick Young
Rep Power: 15 |
I'm tracking some particles from the inlet of my system to the outlet of the system. After I run the simulation, I "Export-->Particle History Data" and save a file of particle tracks.
My question is, how can I reduce this file size? Preferably by increasing the time step... I've played around with it in the DPM settings, but after I change the time step and re-run the simulation, the file size is the same. Any thoughts? |
July 21, 2010, 09:25 |
Chris
Rep Power: 16 |
You might be able to compress the files to reduce their size. See 4.1.5 in the fluent 6.3 user guide.
July 21, 2010, 16:01 |
Patrick Young
Rep Power: 15 |
Compressing the files is not what my issue is... I process the data in another program after. When I open the particle track data in the second program, if there is too much data the program wont work.
I need to reduce the file size, not by compressing the output file, but by making it smaller by increasing the time step/reducing the number of points |
tecio compilation errors in latest 1.6.x | rsamuel | OpenFOAM Bugs | 2 | June 25, 2021 08:10 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
gcc and executable file from Mac to Linux | simone Marras | Main CFD Forum | 0 | April 8, 2007 15:49 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
