symmetric flow
Old   July 26, 2010, 05:17
Default symmetric flow
lehoang_mai's Avatar
User_CFD
lehoang_mai is on a distinguished road
Hi all friends! I simulated model 3D in symmetric flow and computed onehalf of flow. after iterations, I want to compute force(lift and drag) of model. But their values to small (half) in comparison with experiment's values.
Please tell me how to do! Thank you for reading! (sorry for my english)
lehoang_mai is offline   Reply With Quote
Old   July 27, 2010, 01:12
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
You are computing one half of your model, and you are getting one half of expected result.........
Fluent doesn't multiply automatically the results for reaching the total result (ie: without symmetry). I mean it returned you the results for the computed domain (one half)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 27, 2010, 04:30
User_CFD
Thank -mAx- very much!
You're right, it returned me the results for one half of domain. But I viewed results in field flow (pressure, velocity....), they're same as in field flow of full domain. Do you know, how to calculate lift anf drag in symmetric situation in order that It returned me same results in full domain?
Old   July 27, 2010, 05:34
-mAx-'s Avatar
Maxime Perelli
If you are computing one half of geometry, the pressure and velocity won't be multiply by 2 for the full domain.
it is a question of section.
For instance the pressure force on a body will be multiply by 2 for the full domain since the surface is double (projected forces normal to symmetry don't have to be multplied by 2, since they will be compensated).
To your question, then you need to give the right Area in the reference values.
Old   July 27, 2010, 06:27
User_CFD
Thanks you for reply!
And more little question from me. If I will compute one half of geometry, then the pressure force (and total force) on a body will be multiply by 2 for the full domain, isn't it?
Old   July 27, 2010, 06:45
-mAx-'s Avatar
Maxime Perelli
yes, but not in the normal direction to your symmetry (here it should be 0)
Old   July 27, 2010, 06:56
User_CFD
Thanks you very much!
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Steady state Ruben Main CFD Forum 43 May 7, 2011 03:32
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
