August 1, 2010, 02:04 |
Radiation Model: Discrete Ordinate method
rabbahs
Dear All,
I am trying to model combustion in a reactor. The geometry is 2D-axi symmetric, composed of a rectangle having an inlet and out let. From inlet the coal particles (via injector) along with oxygen is coming, after combustion mixture of CO2, CO and other gases leave the reactor. From short side of the rectangle there is a heat flux is coming into the reactor which is supposed to be absorbed by coal, refractory wall of reactor and gases. Now, when I select the Discrete ordinate method for radiation Heat transfer in Fluent. It always ask Absorption coefficient, Scattering coefficient and reflective index for all solid and fluid material type in MATERIAL panel. So, Specifically my questions are, 1) for each gas phase (CO2, CO, H2, H2S and other gas species) where I can find the absorption coefficient, scattering coefficient and reflective index ? Is there some sort of data base available ? Please keep this in mind that the temperature and pressure of the mixture of gas will change during combustion. 2) For solid species ( coal particle and Re-factory wall of reactor) where I can I find the absorption, scattering coefficient and reflective index. Or the value of these coefficients are zero, as these material are opaque ? This is really very confusing, because in all my heat transfer studies I only learn about emissivity, transmittance, reflectivity, absorptivity etc. I will be glad that any one can answers my question. Thanks |
March 2, 2014, 21:55 |
Muhammad Uwais Zuraidi
hi shabbarraza2000
did you manage to find the coefficients? |
March 3, 2014, 00:04 |
rabbahs
New fluent version provides the absorption coefficient for most of the species. I am using fluent 14. let me know.
April 11, 2014, 21:48 |
#4 | |
rabbahs
I am unsure that you can find some specific example for your case. but try to start the 3D version of fluent and do some baseline work to match your results with analytical calculation. Thanks |
absorption coefficient, discrete ordinate model, radiation, refective index, scattering coefficient |
Radiation Model | Nicki Parker | CFX | 2 | August 7, 2007 09:35 |
Discrete phase model in porous media | Pradeep | FLUENT | 0 | February 3, 2006 16:30 |
DO radiation model | jarno brunetti | FLUENT | 0 | January 21, 2006 15:52 |
questions about the discrete phase model | lisa | FLUENT | 3 | January 17, 2006 07:51 |
Discrete Ordinate Model | Raffi Kazazian | Main CFD Forum | 1 | January 4, 2000 02:25 |
