UDF:DEFINE_DPM_BC(AD_SCAF,p,t,f,f_normal,dim) |
May 23, 2006, 15:04 |
hI, with this little UDF I have to impose this simple BC to a Porous Jump interior surface: 1 - if particle identity is equal to selected number, trap particle; else 2 - apply the 'interior' attribute to my surface, so continue with tracking particle.
the problem is: in case 2 - particles stop their run! It is wrong!!!!! Sigh please any suggestions?!? I'll be crazy very soon! Many thanx to helper!! Cheers Adriano ps: this is the code. DEFINE_DPM_BC(ADESIONE_SCAF,p,t,f,f_normal,dim) { int select,l; FILE *fp; /*TO call function that makes the comparison */ select=confronta(p->part_id, a); if (select==1) { Message("select = %d part_id ferma = %d\n",select,p->part_id); fp=fopen("ADESIONE_SCAF.txt","w"); fprintf(fp,"((%10.6g %10.6g %10.6g %10d %10d %10.6g %10.6g %10.6g) %d)\n",p->state.pos[0],p->state.pos[1],p->state.pos[2],t,f,f_normal[0],f_normal[1],f_normal[2],p->part_id); fclose(fp); Trap_Particle(p); l=PATH_ABORT; } if (select==0) { l=PATH_ACTIVE; } return l; } |
April 25, 2017, 03:12 |
Yoon
Rep Power: 11 |
I stuck on this problem..
Did you get any answer of it?? |
April 26, 2017, 02:03 |
Rep Power: 9 |
August 9, 2018, 02:08 |
have you solved the problem?
hxw
Rep Power: 10 |
