floating point error!
hi every body ! :)
I made my geometery in gambit(2 part)! then I merged them, and read them in fluent! when I run this file I get only these, nothing else!!! :confused: iter continuity x-velocity y-velocity z-velocity k epsilon time/iter reversed flow in 1440 faces on pressure-outlet 11. turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 64505 cells 1 1.0000e+00 2.2368e+04 1.1092e-07 4.1418e-01 9.2458e+08 9.6332e+16 0:19:56 299 reversed flow in 501 faces on pressure-outlet 4. reversed flow in 203 faces on pressure-outlet 11. turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 308949 cells Error: Floating point error: invalid number Error Object: () what is this error:mad:?????????? is there anybody to help me? please! I look forward 4 ur answer dear:). |
Floating error and Same results u r getting
Hello
i am getting floating error:invalid number. I am working on train travelling in tunnel. Can any body help me. My email is sheikhnasir39@gmail.com thanks |
check your boundary conditions and specify correct pressure, velocity values. You get floating point error when some number gets divided by zero durning your iterations. Hope it helps
