Particles faster than fluid
Hi ,
The case i am currently working on seems to be quite simple nevertheless i find a probelm which is keeping me from having coherent results. The case is the flow of a fluid (air) in a pipe . There are heavy particles carried by the flow. When i show the display of the particles velocity i find that the particles reach a higher speed than the fluid which can not be correct. This problem is delaying me and since it is gonna be soon the end of my internship and I need to solve this problem. Please if someone has ever encountered this kind of problem and have found the solution... Thanks for your help |
Hi, yomanu,
We have to know what multiphase flow model is used in the simulation and more detail about the model and the results. |
I don't know which multiphase model would be the best .The guide tell to use mixture or eulerian but i have troubles defining it...and the results still show that the particles are faster than the fluid.
Thanks |
