parallel switching
Old   August 19, 2010, 21:31
Default parallel switching
Mohsin Mukhtar
Mohsin is on a distinguished road
Is it ok to switch between Parallel processing and non parallel processing. As with parallel processing the SWAP and moothing feature is not applicable so for swaping and smoothing feature can we work withnon parallel processing and for iterations switch to parallel processing.
would it have any effect on calculations and solution?
Thanks for your help.
Mohsin
Mohsin is offline   Reply With Quote
Old   August 20, 2010, 01:41
-mAx-'s Avatar
Maxime Perelli
you can run a job in parallel, after x iterations you can write case and date.
Then ready the case and date in serial and re-iterate.
Take care always writing case
Old   August 20, 2010, 01:44
Mohsin Mukhtar
Max thanks for ur reply
After 5000 iterations (when i got convergence) I changed to non parallel solver and start iterations again. there was a drastic rise in residuals but they reduced to convergence after some iterations.
I hope i m doing the same which u said here.
Old   August 20, 2010, 03:26
-mAx-'s Avatar
Maxime Perelli
yes I experienced it too. (just take care writing data file AND case file together.
Because if you read case (saved from parallel) and data file (saved from serial), then you get weird results.
Regarding the residuals drop it is ok. You get the same if you change any numerical schema or whatever
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 03:07
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
