-   -   Velocity contours (http://www.cfd-online.com/Forums/fluent/79330-velocity-contours.html)
Mohsin August 19, 2010 23:38
Velocity contours
Hello
I am simulating the cyclone. After convergence when i check the velcoity contours of axial and tangential velocity all over my domain (inlcuding walls, middle plane, horizontal plane in the middle everywhere) the tangential and axial velocities are coming as 0.
I have specified velocity magnitude in the boundary conditions.
Could anyone explain?Thanks
Mohsin
-mAx- August 20, 2010 04:01
If you specified velocity Magnitude in Inlet-velocity BC-Panel, then the vector points normal to the surface.
You can display pathlines from your inlet for checking if flowfield is in accordance to your wish
Byron August 20, 2010 04:37
Originally Posted by Mohsin (Post 272088)
Hello
Mohsin
Do the other parameters of fluid field right?
I guess that the other parameters are also wrong,such as temperature,pressure.You should check them .
If it is , the only explain is that your compution was wrong.
PS,you could monitor a fixed point in fluid field duiring the simultion.Residual is not a good sign to judge the convergence.
Mohsin August 20, 2010 04:50
yap thank you byron
All other parameters are absolutely fine (surface monitors, residuals, mass flux).
sutiut February 22, 2015 08:59
Hello Dear Moshin,
I have the same problem as you. I can not generate radial & tangentical velocity contours, right.
Could you?
please explain your method.
thanks,
