December 15, 2009, 09:29 |
Rich Flammability Limit
Johann V
Rep Power: 16 |
Hi everybody,
I hope someone can help me with my problem. Thanking you in anticipation. I need to calculate a combustion model (non premixed combustion PDF) and therefore I need the Rich Flammability Limit (RFL). There are, one fuel stream (CH4 85%, N2 11%, C3H8 4%), one oxidiser (O2 100%), and an ambient air stream. I read in the FLUENT documentation that the RFL for the ambient stream can be set to 1. But what do I do with the RFL for the fuel stream? Is this the same as the Lower Explosive Limit (LEL)? |
December 16, 2009, 03:49 |
Johann V
Rep Power: 16 |
Good morning friends of CFD.
I yust calculated the rich limit as folows. f=(Z_i-Z_i_oxi)/(Z_i_fuel-Z_i_oxi) Z_i : mass fraction of (CH4 + C3H8) in respect to the Lower Explosive Limits. Z_i_fuel : mass fraction of (CH4 + C3H8) in the fuel Z_i_oxi : mass fraction of (CH4 + C3H8) in the oxidizer All values were calculated for a volume of 1 m^3. And the result is f=0.03 Is this result reasonable? Any hint and sugestion is velcome. |
August 25, 2010, 23:12 |
#3 | |
Dong Liang
Rep Power: 16 |
the f is the mixture fraction. Z_i is the mass fraction of i element, like C, H, O, etc. the result is only one with any element in the system. the RFL is a constant that the fluent will compute the chemistry when the f is above it. in most cases, it will be larger than chemical equivalent. |
how to increase "Newton Pressure Iteration Limit" | kus | CFX | 9 | April 21, 2013 01:54 |
limit holdup value | mohini | CFX | 2 | July 31, 2008 03:58 |
How to limit a variable | ash | OpenFOAM Running, Solving & CFD | 1 | June 26, 2008 20:32 |
mesh adaption memory limit | Dave | FLUENT | 1 | March 27, 2004 09:02 |
Data size limit | Kaokanya | Siemens | 2 | January 6, 2004 08:32 |
