Inviscid flow on blade does not converge, why??
Old   September 8, 2010, 14:49
Unhappy Inviscid flow on blade does not converge, why??
Arash
arash_7444 is on a distinguished road
Dear all,
I simulate a stationary blade in inviscid flow but the solution does not converge. the problem is on Continuity residual because it is not going lower than 10e-2.
do you have any Idea or suggestion?
thanks in advance
arash_7444 is offline   Reply With Quote
Old   September 10, 2010, 08:53
Unhappy
Arash
Also I think my mesh Quality is fine enough (Maximum Equiangle Skewness is 0.86) and I used POINTWISE in order to mesh my geometry.
in fluent, I tried all of the numerical scheme such as first order upwind scheme or Quick Sheme .... :-(
Old   September 14, 2010, 00:43
srr
srr
srr is on a distinguished road
All the time I have convergence problems I check the wall y+, it usually shows the cells where the problem exists (where it is really high y+ values), so I introduce a mesh density it that point to improve quality. Your skewness is good, but there might be a problem with aspect ratio, squish, ....
I hope this help you
srr is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Re: how to do this turbine blade passage flow nanl manish Fidelity CFD 1 November 2, 2006 23:01
Re: how to do this turbine blade passage flow nanl manish Phoenics 1 February 21, 2006 09:59
Boundary Layer created by Euler Solvers Jim Main CFD Forum 31 November 17, 2001 23:18
Velocity Gradients at Inviscid Flow Lada FLUENT 0 January 15, 2001 07:20
