April 8, 2010, 01:39 |
FLuent Parallel Error.
Rep Power: 16 |
Hi everyone,
I am simulating a 3D dynamic stall phenomena of an airfoil. I use the dynamic mesh method to smooth and remesh the mesh at every time step and a udf to pitch the airfoil and i have a non conformal interface. I initially run the steady state solver in parallel with 4 processes for 2000 iterations w/o dynamic mesh and udf and it runs fine. But when I switch dynamic mesh and transient solver on, the simulation crashes after approximately 300 time steps with the following message : 999999 (..\src\mpsystem.c@1148): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory The Parallel FLUENT process could not be started. Does anyone know what can cause this problem? For your information I am running Fluent v12 with an i7 860 quad core with 8gb of RAM and my mesh size is approximately 2.5 million. Regards, Darren |
April 10, 2010, 21:26 |
Rep Power: 16 |
Anyone out there knows whats the problem? Im desperate to get this problem fixed....
Cheers Darren |
July 9, 2010, 15:22 |
Burak
Rep Power: 16 |
I have same problem too, anyone have any solution??
July 22, 2010, 17:26 |
Rep Power: 15 |
Sometimes, it may help to turn of Dynamic mesh load balancing in the parallel->partition and load balancing panel
September 14, 2010, 02:06 |
I had this same problem, but got rid of it when I went back to Pointwise (from which I had exported the grid) and defined the volume conditions. This worked for me on two separate cases so it's definately worth a try.
erros when compiling simpleSRFFoam | examosty | OpenFOAM Installation | 12 | April 26, 2010 18:53 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
error in fluent parallel version-can anybody help! | user | FLUENT | 0 | February 16, 2009 02:04 |
error of Parallel fluent in 3d -t2! | sanmango | FLUENT | 1 | May 18, 2005 11:26 |
error parallel fluent session | Diet | FLUENT | 2 | January 27, 2005 12:31 |
