UDF unit and FLUENT output
Like Tree1Likes
  • 1 Post By byronsmith
Old   September 14, 2010, 22:52
Default UDF unit and FLUENT output
ALAM
saifulraju is on a distinguished road
I am using UDF for particle reaction rate. But the difficulty is the consistence of unit. In my UDF(given below) equation the unit is per second. But the FLUENT gives the unit kgmol/m2-s after convergence. Could you please tell how can I get the same unit in FLUENT solution. Is it possile to plot rate of reaction versus time?
/* UDF of specifying the surface reaction rate of a particle */
#include "udf.h"
#define A3 1.36e6
#define E3 1.38e8
#define n3 0.68
#define shi 2.0
DEFINE_PR_RATE(user_pr_rate,c,t,r,mw,pp,p,sf,dif_i ,cat_i,rr)
real ash_mass = P_INIT_MASS(p)*(1.-DPM_CHAR_FRACTION(p)-DPM_VOLATILE_FRACTION(p));
real one_minus_conv = MAX(0.,(P_MASS(p) -ash_mass) / P_INIT_MASS(p)/ DPM_CHAR_FRACTION(p));
if (!strcmp(r->name, "reaction-3"))
real kp3 = A3*exp(-E3/UNIVERSAL_GAS_CONSTANT/P_T(p));
real kd3 = 2.303*log(one_minus_conv);
real ke3 = sqrt(1-shi*kd3);
*rr=-kp3*one_minus_conv*ke3;
With thanks,
Alam
saifulraju is offline   Reply With Quote
Old   September 15, 2010, 02:31
Byron Smith R J
byronsmith is on a distinguished road
hai
The rate of surface reaction should be fed in kmol/m2 s only. whatever you give through ur udf will be computed and expressed by fluent in its unit only. so convert the unit kg/s into kmol/m2 s in hte udf and try the solution
byronsmith is offline   Reply With Quote
Old   September 15, 2010, 11:52
ALAM
Thank you. But if the rate of reaction has the unit (per second), it is not possible to convert in kgmol/m2-s.
So what will I do in this case?
Old   September 16, 2010, 00:35
Byron Smith R J
hai
you can manupulate the unit 1/s by multiplying the rate obtained by density, divide by surface area per unit volume and molecular weight (1/s x kg/m3 xm3/m2 x kmol/kg = kmol/m2 s. hope this helps
Jianqi Shen likes this.
Old   September 21, 2010, 22:22
Default time vs rate of reaction
ALAM
Dear Byron Smith R J,
Thanks. I got the point.
Could you please tell me how can I get the numerical data for plotting time versus rate of reaction.
UDF about reaction in fluent5.4 Mark FLUENT 5 May 1, 2014 17:39
unit conversion of pre-exponential factor A of chemkin mechanism in Fluent newbie FLUENT 5 November 14, 2010 05:44
absolute pressure unit in Fluent? shuqin FLUENT 0 May 23, 2006 08:44
unit of fluent yinyue FLUENT 0 November 3, 2004 08:57
Some problems about UDF in fluent5.4 Mark FLUENT 2 August 14, 2001 08:03
