Home > Forums > FLUENT
What value Turbulent Intensity?
Old   September 18, 2010, 06:58
Unhappy What value Turbulent Intensity?
kamal galedarzade
kamal_g65 is on a distinguished road
Hi all
I want simulate a two stage centrifugal pump, by Fluent. Pump contains: inlet that is a bent pipe, two impellers, diffusers and outlet is a dual volute. I want use Multiple Reference frame (MRF), but, whereas the pump geometry are 3-D and complex shape, I have many problem for simulate in FLUENT. I need help.
Problems are in the below:
1-What value suitable for “Turbulent Intensity” for pump inlet? 2% or more percent?
2-What is correct turbulence model? Standard k-e? Or RNG k-e? Or Realizable k-e?
3-What value suitable for “Under relaxations” for convergence a solution?
4-What suitable method for ” Discretization pressure” (with consideration to model)? Standard? Or PRESTO! ? or etc?
kamal_g65 is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to calculate Turbulent Intensity? prem FLUENT 8 March 21, 2012 14:40
Turbulent intensity for pressure Outlet Boundary condition Mohsin FLUENT 1 April 30, 2010 10:36
Turbulent intensity swe704 Main CFD Forum 0 November 13, 2009 04:42
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Turbulent Intensity good or bad for a jet Christian Main CFD Forum 0 November 19, 2003 06:47
