Home > Forums > FLUENT
flow through vertical pipe
Old   September 21, 2010, 00:39
Default flow through vertical pipe
Praveen Mishra
pmishra76 is on a distinguished road
i am using fluent 6.3, and new to FLUENT , i am facing some difficulties while using fluent when working with vertical pipe.( in horizontal pipe flow every thing is ok) , my difficulty is while doing iteration, it gives Error:Floating point error: invalid number.
pmishra76 is offline   Reply With Quote
Old   September 21, 2010, 02:21
Phoevos
fivos is on a distinguished road
Are you using axis-symmetric solver? In that case, the axis of symmetry can be ONLY the X-axis (else you will get errors). If you want to model the vertical pipe you should design it as a horizontal pipe (on the X direction) and put gravity on the X-axis.
If you are not using axis -symmetric solver, then you must have done something wrong in the case set up. Do it again in the same way you did it for the horizontal pipe.
fivos is offline   Reply With Quote
Old   September 21, 2010, 02:41
Praveen Mishra
Dear fivos
yes, i am using axis-symmetric solver.but instead of horizontal pipe, i made vertical pipe......now i am trying with horizontal pipe.
thanks
Old   April 28, 2014, 11:01
Default Vertical pipe
Goutam Saha
Goutam is on a distinguished road
I am using a vertical pipe. I draw a 2D axi-symmetric horizontal pipe and I set the Boussinesq option available in the material panel (Density). I also set the gravity along X direction g = -9.81 m/s).
Is this settings correct for vertical pipe with Boussinesq approximation?
What will be the operating Temperature when I will set the gavity option enable? Is this the room temperature?
Thanks for your time.
Goutam is offline   Reply With Quote
Thread Tools
Trackbacks are On
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 10:14
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 05:04
Domain for Pipe Flow Swarup FLUENT 0 September 28, 2005 23:25
outlet boudary condition for a flow in the pipe Atit CFX 2 November 9, 2004 18:43
