September 23, 2010, 08:24 |
problem with UDF drag !!!!
Rep Power: 17 |
Hello everybody!
I am facing to the problem with user defiend drag. I have a water flat jet (DPM) and continuous phase (air). I have to consider two- way coupling between water droplets and air. When I use spherical drag law, everything works well. But as soon as I switch to user defined DPM, problems appear - there is no momentum exchange between phases!!! This is not definitely problem of UDF, it must be somewhere else. Does anybody know the answer??? Please? Honza |
September 24, 2010, 09:14 |
problem solved
Rep Power: 17 |
Hi there, I solved the problem and must hit the wall with my head. The UDF was not working since I put constants like 15 instead of 15.0
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
UDF using problem, error happens-heip!! | Michael | FLUENT | 1 | December 9, 2008 07:51 |
UDF problem | mansha goraya | FLUENT | 0 | October 29, 2007 00:31 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 07:14 |
I have problem of UDF with turbulent premx source. | Z | FLUENT | 0 | February 16, 2005 03:34 |
