Multiphase heat transfer
Old   September 24, 2010, 11:06
Default Multiphase heat transfer
Khurram
deep_seak is on a distinguished road
I want to simulate the multiphase heat transfer mechanism occurs in a typical heat pipe. I have used vof model using the udf provided in the tutorial named boiling.c. But there is no condensation happening at the evaporator section. If anyone has some idea about incorporating the condensation phenomenone in this udf then please share.
deep_seak is offline   Reply With Quote
Old   September 24, 2010, 14:26
ABHISHEK VYAS
abhishek_vyas is on a distinguished road
Hi Deepak,
You can Mixure model in FLUENT, when you set the phases in the "PHASES" option you will find the evaporation-condensation in the Mass tab.
Try with this and lemme know!!
Abhishek
abhishek_vyas is offline   Reply With Quote
Old   September 25, 2010, 05:02
Khurram
thanks for your reply,
I tried as per your suggestion but when i go to interaction and then to mass tab, there is one check box for cavitaion and other one asking for number of mass transfer mechanism. There is no evaporation-condensation option there. My Fluent version if 6.2.16
Old   September 25, 2010, 10:38
ABHISHEK VYAS
when it asked for mass transfer option you specify no.1 there and then you will see the evap-cond option enabled. Since I am using version 12.0 it is there.
Old   October 8, 2010, 09:56
JohannVV is on a distinguished road
Originally Posted by deep_seak View Post
Hi deep_seak, i have to realize a heat exchanger therefore i need to write a udf. could you send me the tutorial wit the boiling.c file?
JohannVV is offline   Reply With Quote
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Heat Transfer in Multiphase Models (Star CCM+) Luke Treadwell Siemens 2 September 7, 2008 20:14
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
is there heat transfer option in multiphase model gayaz FLUENT 1 July 16, 2003 11:13
