message during background implementation
Hi there
I'm doing background calc in linux and below is my input file autosave is set as 20 timesteps in the case file. ------------------------------------------ rc 2DAxiLPnoGD_PBS_LES_002.cas /solve/initialize/initialize-flow /solve/set/flow-warnings? no /solve/set/limiter-warnings? no /solve/set/time-step 0.001 /solve/dual-time-iterate 5000 wd 2DAxiLPnoGD_PBS_LES_002.dat exit y ------------------------------------------ In outfile I found some error messages as below ------------------------------------------ Number of iterations per time step [20] Error: eval: unbound variable Error Object: wd Invalid integer. Error: eval: unbound variable Error Object: 2daxilpnogd_pbs_les_002.dat Invalid integer. Number of iterations per time step [20] Invalid integer. Number of iterations per time step [20] Error: eval: unbound variable Error Object: y Invalid integer. Updating solution at time levels N and N-1. done. iter continuity x-velocity y-velocity energy plume pre_out_mo time/iter 20 7.0893e-01 3.9029e-02 3.0250e-04 2.4189e-06 7.0563e-02 1.0132e+05 0:00:00 0 Flow time = 0.001s, time step = 1 4999 more time steps ... ------------------------------------------ What is wrong with my input file? thanks in advance |
have you created your input file in windows? I faced a similar problem, but in linux i converted the file into linux format by dos2linux filename..
Hope this is useful |
