DPM model
Old   September 29, 2010, 10:06
Exclamation DPM model
Panos
panos_metal is on a distinguished road
Hello
I simulated the flow of air in a verical tube (d/L=0.05)which is heated by its sides (wall constant temperature). The air inlet is on the top of the cylinder and its moving downwards to the pressure outlet.
Now i wanted to insert sand from the top of the tube which will move due to gravity downwards. I decided to use the Discrete Phase Model and inducing particle trajectories to see the behaviour of the solids. When i set the particle trajectories i have to set the inlet bvelocity of the solid..but the velocity is 0 m/sec in my case. In addition the velocity of the solid on the outlet is not known so i cannot set it. Can you recommend me another way to use DPM?
I would like to simulate the flow of 0.1 kgr/ minute. The perlite inlet diameter is 3 cm.. Can you recommend me which is for you the appropriate type of injection?
Thank you in advance
panos_metal is offline   Reply With Quote
Old   October 1, 2010, 04:36
Mohsin Mukhtar
Mohsin is on a distinguished road
You can use Surface or Group injection.
firstly I would recommend you to use surface injection with uniform diameter. when u clik on surface then You have to give surface name from where the particles are injected. Then you can give 0 m/s velocity of the particles from that surface and get the result.
Good luck
Mohsin
Mohsin is offline   Reply With Quote
Old   October 2, 2010, 03:31
Panos
Good luck
Mohsin
Goodmorning and Thank you Mohsin.. That seems to work better
dpm, injection, two phase flow
How to put melting Point data of inert particle in DPM model subhankar_bhandari Main CFD Forum 0 July 26, 2010 07:28
dpm model cxy FLUENT 1 April 16, 2008 06:30
DPM model in FLUENT Jürgen Schmidt FLUENT 0 October 27, 2005 14:39
DPM vs Species transport model osh FLUENT 0 August 19, 2005 22:15
missing mass from dpm model Jan Rusås FLUENT 0 March 23, 2005 18:05
