heat exchanger
Old   February 5, 2004, 10:09
Default heat exchanger
venkat
hi all..I am new user of cfd-fluent...I am working on heat echanger model..where air as inlet alumenium as wall at higher temperature..my problem is, I assume that water drplets may form on fins(al). I want to model water(drops) zone on fins in gambit. I am using fluent 6.0 .Should i mesh the water droplets? what type of boundary condition should use? need of any continuum type to specify? thanks in advance
Old   October 4, 2010, 00:43
Default double pipe helical heat exchanger
abhinav prasoon is on a distinguished road
can anyone help me in finding the bc for double pipe helical heat exchanger in which mass flow rate has been given for inner pipe and annulus pipe ,with inlet temp of cold fluid and inlet temp for hot fluid.
abhinav prasoon is offline   Reply With Quote
Heat Exchanger Model sak2129 FLUENT 3 September 26, 2017 01:29
Macro Heat Exchanger not selecting (Please help!) zdeth FLUENT 2 September 11, 2012 13:52
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Heat Exchanger Simulation tightaznbreaka FLUENT 0 March 18, 2010 15:45
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
