How to solve natural convection problem in fluent?
Old   October 9, 2010, 09:59
Default How to solve natural convection problem in fluent?
subho
samantasubho is on a distinguished road
Friends, I am trying to solve a natural convection problem in FLUENT (natural convection from a horizontal flat plate) with prescribed wall heat flux.
For the problem I have given the boundary conditions as: left and right part of control volume: pressure inlet and top part of the control volume pressure outlet, wall prescribed heat flux.The fluid is air with Pr=0.7
After 1300 iterations also my solution is not converging. Kindly help me if possible.
samantasubho is offline   Reply With Quote
Old   October 18, 2010, 07:39
Erik Hultman
hultman is on a distinguished road
I assume that it is a steady-state run, or do you mean 1300 outer iterations?
hultman is offline   Reply With Quote
Old   October 21, 2010, 04:41
Logan Page
Logan Page is on a distinguished road
add an image of your mesh and BC's if u can.
Logan Page is offline   Reply With Quote
Old   September 3, 2012, 12:06
sa
saharesobh is on a distinguished road
I am trying to solve the natural convection (mixed convection) in a Chemical vapor deposition reactor. The reactor has top and bottom plates and inlet and outlet tubes. The reactor is heated by top smaller rectangular plate embodying two heating rod. the top plate is at 250 oc and the bottom plate is at 150 oc. So because of temperature gradient, the natural convection will occurs. When I go to the boundary condition, then I go to hot plate, I see the heat flux (w/m2) and the heat generation rate (w/m3). My question is that, should I need to get the heat flux and geat generation and then put them in Fluent or the fluent get them? would you please give me some advice. I don't know why I cannot see the roll-type flow between two parallel plate?As for heat trasnfer coefficient, I don't know how can I get it? I am really confused .
saharesobh is offline   Reply With Quote
Old   September 4, 2012, 06:09
Elias Paez
sicfred is on a distinguished road
HI Saharesobh,
First, when you go to boundary conditions hot plate, you just need to put the temperature in the plate, if you put heat flux or heat generation rate you are changing the boundary condition of your plate; this two values are going to be calculate by fluent after you running the simulation (for example in wall fluxes).
Second, if i understood your hot plate is in the top and the cold plate is in the botton, that means that there is not natural convection, you need the heat source in the bottom (or change the direction of the gravity XD)
sicfred is offline   Reply With Quote
Old   September 5, 2012, 13:04
sa
Thank you so much for your response.
You are absolutely right. You know I asked my advisor about this problem( As you said the hot wall cannot be on the top ). She said this roll-type flow is made due to the momentum and prandtl number.Because I am using HTB fluent ( Hafnium tetra Butoxide). Due to these reasons I have natural convection and roll-type flow, Is it alright if I send you my file and you look at that? I can give you my email adress if it is Ok with you. Thank you so much in advance
Old   October 14, 2012, 08:20
sagila
sagila is on a distinguished road
Hi saharesobh,
I have a tall room with a hot roof that natural convection occurs in it. The side walls are at the same temperature and the floor is adiabatic. I have problem for converging it. Could you please let me know whether you have problem with convergence for your case which is similar to my case? If yes, could you please let me know how you solved it?
Thank you in advance.
sagila is offline   Reply With Quote
Old   April 17, 2014, 02:07
Svetlana Tkachenko
Светлана is on a distinguished road
I have same issue, I'm sure you solved it back then?
Светлана is offline   Reply With Quote
problem naturalconvection
Natural convection in Fluent smpandey Main CFD Forum 3 February 26, 2010 01:28
natural convection problem in cfx NVSD BABU CFX 7 November 13, 2008 10:56
Can FLUENT solve this type of problem? Whitaker FLUENT 3 October 23, 2000 03:01
Meshing a natural convection problem sandeepmishra FLUENT 1 May 31, 2000 14:36
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
