rotating propeller in stationary baffled vessel
Old   October 10, 2010, 12:21
Default rotating propeller in stationary baffled vessel
raymond
wlt_1985 is on a distinguished road
I would like to model a rotating propeller inside a stationary baffled vessel with water as the fluid inside. I had a lot of trials. Unfortunately, in all my model, the rotating propeller always rotating with the baffled vessel. I do not know which part I am making wrong. Does anyone how to model the correct model in this case? Please help me. Thanks.
wlt_1985 is offline   Reply With Quote
Old   October 11, 2010, 02:51
-mAx-'s Avatar
Maxime Perelli
The easiest way would be to treat your problem with sliding mesh.
Basically you need 2 regions which are not connected: rotor and stator, and then define interfaces
Old   October 11, 2010, 03:03
raymond
Thanks for help. I tried to model with two regions, one is the solid propeller and another is water fluid. When trying to define the interface between this two region, message has been shown as below:
Warning: materials in neighbor cell threads (3 and 4) of interior zone 14 are of different types (aluminum and water-liquid). This problem MUST be fixed before solving!
I totally do not have idea in solving it.
Please help.
Thanks
Old   October 11, 2010, 03:09
-mAx-'s Avatar
Maxime Perelli
not like that.
Substract your solid region (you should have empty area instead of solid impeller)
Then if your geometry enables it, draw (split) a circle around your rotor.
You have now 2 regions, the disk which is your rotor, and the outer domain which is your stator.
As I said you need to disconnect your 2 regions, for applying interfaces.
Check online help chapter 11.2 Sliding Mesh Theory
Old   October 11, 2010, 04:23
raymond
not like that.
Thanks for your help. If I would like to model the motion behavior of the fluid (initially which is stationary) which is affected by the motion and shape of the solid stirrer inside the stationary baffled vessel, the solution mentioned above still valid for it? Or any modification should be applied?
Really thanks to your help.
Old   October 11, 2010, 04:30
-mAx-'s Avatar
Maxime Perelli
what I mentionned above is just the geometry / mesh side (no physics).
How they move, can you explain later in fluent (not in gambit)
Old   October 11, 2010, 05:24
raymond
Thanks. One more question, if I split my rotor (impeller) by using a geometry which has the same shape but larger size to my rotor (impeller) instead of a circle, does it work for my sliding mesh model?
Old   October 11, 2010, 05:37
-mAx-'s Avatar
Maxime Perelli
no.
The split should be a circle.
For undestanding, try to imagine a split like a star. If you rotate your star with 10°, you cannot superpose rotor and stator regions.
Old   October 11, 2010, 05:48
raymond
no.
In order to split my rotor (impeller) by using a geometry which has the same shape but larger size to my rotor (impeller) instead of a circle, does it mean that I need to use dynamic mesh?
Old   October 11, 2010, 05:51
-mAx-'s Avatar
Maxime Perelli
if you cannot create a circle-split, then yes you will have to handle with dynamic mesh.
Can you quick post a sketch of your rotor-stator?
Old   October 11, 2010, 06:11
raymond
Here is my initial gepmetry
Old   October 11, 2010, 07:00
raymond
Here is my initial geometry to be studied. What should I do in order to have best model of the fluid motion behavior which induced by the solid impeller? Thanks a lot.
Old   October 11, 2010, 07:24
-mAx-'s Avatar
Maxime Perelli
your picture is quite small...
As far as I saw, you can draw a circle (cylinder-surface in 3d) surrounding your impeller.
You can also attach your geometry (*.dbs) if you want
Old   October 11, 2010, 08:20
raymond
I would like to attach my dbs file. Unfortunately, it was around 1M and error during attaching. I tried to model as solution provided before and it was work. Thanks for your help. The cylinder should be just created surrounding the impeller or it should be huge enough until close to the stationary baffles?
Old   October 11, 2010, 08:23
raymond
If I would like to model it with dynamic mesh, what should I do to the model setting?
Old   October 12, 2010, 01:01
-mAx-'s Avatar
Maxime Perelli
so I received your file.
Do followings:
*delete volume2
*create cylinder (height 0.2 / radius 1=radius 2=0.04 / Axis Location Positive Z)
*split volume1 with the cylinder (volume4)
*delete volume5 (solid) --> should be already deleted (volume2) but it's early this morning, don't want to investigate )
here we are, you have 2 regions: rotor and stator.
*copy volume1 with translation (0.1 0 0) (it generates volume 5), delete volume1
*move copied volume5 with translation (-0.1 0 0)
* The 2 volumes are now disconnected.
Apply interfaces (one for each volume)
Old   October 12, 2010, 01:23
raymond
Do followings:
*delete volume2
Thanks for help. Max.
Old   October 13, 2010, 13:45
anonymous
cfd_confuse is on a distinguished road
Hi Max, for the above mixing tank problem, may i know what is the ideal number of cells for both the moving zone and the fluid zone, in a 2.5m tall cylindrical tank?? Also, may i know how to go about setting the boundary condition in fluent?
cfd_confuse is offline   Reply With Quote
Old   October 14, 2010, 01:23
-mAx-'s Avatar
Maxime Perelli
There is no rule. Just check that you have enough cells where you think there is pressure drops etc...
Old   October 14, 2010, 08:14
anonymous
Hi Max, what about the boundary condition to set in fluent? i am not sure about the boundary condition to be use for the mixingtank
Rotating propeller in a finite freestream velocity asma CFX 9 January 7, 2014 06:14
Counter rotating propeller (propfan) Ball FLUENT 0 August 13, 2008 16:14
Rotating Propeller Nolin FLUENT 1 September 6, 2006 23:07
propeller rotating at zero inflow velocity Ammu FLUENT 1 July 23, 2005 13:36
Solid particles in a rotating vessel with 5.7.1 Sandeep CFX 0 May 17, 2005 10:54
