Acces to solver variables in UDF
Old   October 12, 2010, 13:28
Arrow Acces to solver variables in UDF
Grzegorz Kondora
kondora is on a distinguished road
How to access solver variables (like boundary conditions setting - for example: defined volume fraction for phase of ID 5 for the velocity inlet zone of ID 4) in UDF? I know that I can easily access scheme variables defined, but how to access this specific setting on boundary zone? Thanks in advance!!!
kondora is offline   Reply With Quote
Old   October 12, 2010, 16:09
csmith_PADT is on a distinguished road
You could use a UDF macro known as DEFINE_PROFILE(), in which you can specify a profile for a boundary zone. In your case, you could create the profile for the volume fraction on the velocity inlet zone. There is a decent example of how to do this in the Fluent UDF manual.
csmith_PADT is offline   Reply With Quote
Old   October 12, 2010, 16:18
Grzegorz Kondora
Ok, thanks. But I'm trying to create an UDF that will be universal, i.e. does not require modifying from the user side. I pretty sure that it is possible to access given settings in FLUENT since those variables are accessed by the solver as well somehow. For example zone name may be accessed by THREAD_NAME(c) while looping over particular domain and thread... Another way to access settings is to use scheme variables, it should have following form: in FLUENT | (%rpgetvar '/bc/wall-ID/phase-ID/vof) | or in UDF | RP_Get_Real("/bc/wall-ID/phase-ID/vof"); |
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF to define variables orlik FLUENT 0 March 11, 2010 11:15
Pressure gradient in UDF for density based solver matzb FLUENT 0 February 22, 2010 06:34
FLUENT variables for the use in UDF sega Fluent UDF and Scheme Programming 2 January 19, 2010 03:41
Accessing Solver data for UDF CFDtoy FLUENT 7 April 13, 2006 16:52
