Help: Third-order MUSCL for flame propagation?
Old   October 7, 2010, 12:19
Default Help: Third-order MUSCL for flame propagation?
fireman is on a distinguished road
I find this from FLUENT HELP:Compared to the second-order upwind scheme, the third-order MUSCL has a potential to improve spatial accuracy for all types of meshes by reducing numerical diffusion, most significantly for complex three-dimensional flows, and it is available for all transport equations.
But, The third-order MUSCL currently implemented in FLUENT does not contain any flux-limiter. As a result, it can produce undershoot and overshoot when the flow-field under consideration has discontinuities such as shock waves.
So can I use MUSCL scheme for simulation of flame propagation? I am not sure that if the flame front has such kind of discontinuities. Thank you!
fireman is offline   Reply With Quote
Old   October 13, 2010, 07:59
sreenivasa rao gubba
sreerao is on a distinguished road
Hi
When you say flame propagation, Can I assume it as premixed flame? Is it in 2D or 3D that you want to simulate?
For instance premixed flames in turbulent situation are not continuous. However, these discontinuties are mainly dependent on your local flow field. If you are using RANS to simulate this problem, I would give it a try and see the difference with different schemes.
Sree
sreerao is offline   Reply With Quote
Old   October 13, 2010, 12:17
Originally Posted by sreerao View Post
Hi
Sree
Hi, Sree
Thank you. I am doing 3D LES simulation of premixed flame propagation in a closed vessel. The flame undergoes laminar and turbulent regime.
Old   October 13, 2010, 12:33
Hi
I would dare to try if my flame is in thin reaction zone regime of the combustion diagram. Again it is purely based on what u' i am using. if it is highly turbulent, i would expect discontinuties.
-Sree
IS calc. with 2nd order discret. always necessary? Azman FLUENT 2 March 14, 2013 04:28
1st order vs 2nd order ken FLUENT 8 March 14, 2013 03:43
How to compute UDS fourth order gradient Emma66 FLUENT 1 April 27, 2010 05:44
Unstable flow simpleFoam 2nd order Valle OpenFOAM 0 August 26, 2009 08:12
CFL condition for higher order schemes Shyam Main CFD Forum 2 February 14, 2008 14:24
