October 13, 2010, 13:42 |
reaction panel or udf
raymond
Rep Power: 16 |
I am going to model a chemical reaction instead of combustion, i.e esterification. Is it a necessary for me to compute the chemical reaction with udf? Or may I just using the reaction panel available in Fluent? Please help.
October 13, 2010, 23:57 |
chétan
Rep Power: 16 |
you can use reaction panel, for reaction between acid and alcohol. UDF will be useful if you want to use customerised reaction rate equation oresle Fluent will calculate reaction rate with inbuilt models.
October 14, 2010, 00:57 |
raymond
Rep Power: 16 |
October 15, 2010, 03:59 |
raymond
Rep Power: 16 |
I have found that the chemical species used in esterification are not available in database. So, I define the individual properties of chemical species. Is it a necessary for me to define the properties of that mixture of chemical species? Can it be just ignored?
October 15, 2010, 12:22 |
raymond
Rep Power: 16 |
I need to define my own chemical species for reaction. Hence I need to define the properties of mixture. The properties of mixture are just for properties of mixture of reactants? Or properties of mixture of reactantsand products? Please help.
October 18, 2010, 02:50 |
chétan
Rep Power: 16 |
you need to define only properties of reactants. Properties of Mixture usually determined by various models by selecting appropriate options from Mixture panel. Mixture panel is the place where you should define your reaction and select species.
October 18, 2010, 07:47 |
raymond
Rep Power: 16 |
UDF about reaction in fluent5.4 | Mark | FLUENT | 5 | May 1, 2014 17:39 |
UDF for catalyst volumetric reaction, temperature overshoot though rate is small | elmcmaster | FLUENT | 0 | October 11, 2010 09:37 |
UDF changing the rate exponent of a reaction | Stefan H | Fluent UDF and Scheme Programming | 0 | September 16, 2009 13:20 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
UDF : Chemical Reaction in Catalytic Converter | adhimac | FLUENT | 1 | March 27, 2001 14:04 |
