hydraulic diameter
hi every body :)!!
i have a 3d geometery ! i define the 3 faces , as inlet ! they are exactly similar[rectangular (14.7* 7.5] !!!!!!!!!!! but when i wanna import the hydraulic diameter in fluent , i dont know that i should import Dh of one of them, or i should import 3Dh:eek:??[ i cant define them seprately !!! because i have total mass flow inlet:rolleyes:] :):)SaHa:):) |
if Q is your total massflow, then generate 3 maflow inlet, with Q/3 each
hi dear mAx !!
i cant use Q/3:confused:! because each cannal has different Q :eek: !!!!!!!!!!!! and that is because of the downstream effect !! [ i only have Q !!] :):)SaHa:):) |
if you choose the 3 faces as one inlet, fluent will automatically dispatch the massflow uniformally since the 3 faces have same section. So you will have Q/3 at each intake.
hi dear mAx!:)
then u mean that fluent cant understand the effect of down stream ! ya? because the results of experimental tests, show different mass flow rate in each cannal :rolleyes:!!!! also , the other question : how can i seperate these planes in fluent? i used surface\plane but i think it uses a infinite plane that cut my geometery in 3 cross section , again!!:o what should i do?:confused: |
the Boundary conditions are given from you. You impose it.
Return in Gambit, and select each intake surface as separated BC (inlet 1, inlet 2, inlet 3) |
