-   -   use batch mode to run an unsteady case (http://www.cfd-online.com/Forums/fluent/81301-use-batch-mode-run-unsteady-case.html)
PaulineP October 22, 2010 09:59
Hi !
I would like to use batch mode to run an unsteady case.
I understand how it work for a steady case reading the example (
; Read case file
rc fluent.cas
; Initialize the solution
/solve/initialize/initialize-flow
; Calculate 200 iterations
it 200
; Write data file
wd example200.dat
; Exit FLUENT
exit)
But for a unsteady case, you cant use "it" and I've looked in the manual and I didn't find the command.
Could somebody help please.
Note that I would like to run a case where I have 1800 time steps of 10s each with 50 iterations per time step.
Thank you very much !
kondora October 24, 2010 14:26
dti n_step n_iter_per_step, for example:
dti 10000 20
PaulineP October 24, 2010 15:50
Do I need to indicate a time step ? How ?
kondora October 24, 2010 16:05
Do you mean time step size??? The value of time step size can be set in GUI before running in batch mode. You can set time step size via journal as well, just search.
PaulineP October 25, 2010 04:33
I tried the dti command. My computer write :
> invalid command [dti]
I don't understand. :confused:
Anyways thank you for your help.
kondora October 25, 2010 04:42
/solve/dti 1000 20
joshr September 16, 2014 17:26
Thank you. It was time saving:)
