continuity convergence in buoyancy driven flows |
March 29, 2011, 04:31 |
Alain
I'm trying to solve a mixed convection flow. All the residuals are dropping except the continuity which is oscillating and decreasing very very slowly. I'm using an incompressible ideal gas for the density with a RNG k-epsilon model. I increased the density of the mesh around the cylinder (representing the human body) and the total number of elements is around 1,700,000. I am monitoring the velocity variations near the human body and it seems they stabilized and the variations are of the order of 10e-5. The number of iterations reached so far is 2700. Should I consider the solution as converged? Why are the continuity residuals oscillating around 1e-3? Thank you |
buoyancy flow, continuity error, mixed convection |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
Buoyancy driven flows | A. Guardo | FLUENT | 9 | March 25, 2004 09:12 |
