udf ....
Old   November 6, 2010, 10:01
Default udf ....
saha2122 is on a distinguished road
Send a message via Yahoo to saha2122
hi my freinds!
i write a udf for the outlet B.C ! i have 8 core pc , & windows is 7 ! i wanna run fluent in parallel on my pc ! is it possible to use udf in this condition????
i look forward for yours attention!!!!!
saha2122 is offline   Reply With Quote
Old   November 7, 2010, 10:11
Default Parallelize
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Yes, you can use udf in parallel, however, you have to parallelize the code. Parallelization is really easy for UDFs due to Fluent's available directive, like RP_HOST, etc. Just look for it in documentation.
You can try using it without parallelization, however, as you said you are using to specify a boundary condition, most likely you are using DEFINE_PROFILE, so, parallelization is must else it will give issues.
vinerm is offline   Reply With Quote
Old   November 9, 2010, 01:30
hi dear
from the last part of your post :[ You can try using it without parallelization, however, as you said you are using to specify a boundary condition, most likely you are using DEFINE_PROFILE, so, parallelization is must else it will give issues]
, do you mean that parallelization of my udf is not necessary even i use parallel fluent ? [because it is the Boundary condition udf?]
ya? do i understand correctly?
Old   November 9, 2010, 01:41
when i interpreted the udf , i get the below message, the error part that i make it bold !!! i dont know if this is an important error, but why in the outlet i can use this boundary udf!!!!!!!! or why fluent allow me to start the iteratation with no problem!!!!!!!!!!!!!!!!!!
cells..
cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig-host.h>" "K:\Yas-Run\89.8.16\diff-draft\pressure.outlet
cpp"
error: udf compiler: cannot execute cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig-host.h>" "K:\Yas-Ru
\89.8.16\diff-draft\pressure.outlet.cpp"
cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<C:/Users/Samaneh/AppData/Local/Temp/udfconfig-node0.h>" "C:/Users
Samaneh/AppData/Local/Temp/pressure.outlet.cpp.0.c"
cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<C:/Users/Samaneh/AppData/Local/Temp/udfconfig-node1.h>" "C:/Users
Samaneh/AppData/Local/Temp/pressure.outlet.cpp.1.c"
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
