Meshing a Mixing Plane using ICEM
Old   November 6, 2010, 17:08
Default Meshing a Mixing Plane using ICEM
W.N. Anderson
Will Anderson is on a distinguished road
I would like to make a mixing plane using ICEM CFD.
Fluent requires that the mixing plane constitute of two parallel and coincident planes. This is the example of a mixing plane in the fluent tutorial.
Two planes of different size, different mesh and different zone but which are entirely on the same geometric plane.
When I try to make a mixing plane in ICEM, ICEM forces the individual surface meshes to share elements, meaning, no parallel coincident planes, rather, a common shared plane.
The blue elements belong to one surface mesh and the green elements to another. These meshes should be separate and on top of each other.
I've tried a lot of things to force ICEM to produce two interior coincident planes which belong to separate zones but nothing has helped. I believe that the step "Repair Geometry / Build Topology" knits the two surfaces together.
Maybe somebody here has made a mixing plane using ICEM CFD.
How did you mesh the mixing plane interface?
Will Anderson is offline   Reply With Quote
mixing plane model: too much backflow and does not converge sbhi FLUENT 1 December 4, 2014 00:31
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
ICEM and symmetry plane Roland CFX 3 September 13, 2006 08:38
Mixing Plane Lee FLUENT 0 August 8, 2003 22:36
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
