Initial conditions - 3D piston/cylinder
Old   November 9, 2010, 20:26
Default Initial conditions - 3D piston/cylinder
Andrew
andyross33 is on a distinguished road
I am very new to Fluent and have used other CFD programs in the past. The simulation I am attempting to run uses a 3D dynamic mesh to recreate a piston/cylinder bore during the expansion stroke.
I would like to set the initial pressure/temperature inside the cylinder, expand the mesh and calculate the new pressure/temperature throughout the volume.
I've got the dynamic mesh component working well. However, and I imagine this is an amateur's oversight on my part, I cannot seem to figure out how to set the initial condition. I can initialize the solution but as I understand it that simply provides a best-guess to help the solver. Where in Fluent do I actually state that there is a fluid in my volume with a given temp/pressure to start with?
Thanks in advance!
andyross33 is offline   Reply With Quote
dynamic mesh, initial conditions, piston cylinder
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
