November 11, 2010, 01:27 |
about warning in fluent
jihyeong
Rep Power: 15 |
Hello guys
my name's ji from Korea I wonder what this warning "multiple subdivision required on zone 8. subdivide using constant ratio done" means I'm using VOF and DYNAMIC layering from FLUENT. The motion and analysis are good. but there is something different from my expectation. So I want to know if that kind of warning is affected to the result of simulation. If anyone knows about the meaning of that plz let me know. thanks |
November 16, 2010, 23:41 |
teguh hady
Rep Power: 17 |
Hi Ji
Well, i ever get warning for my simulation (different case of yours).about 2 phase. because our simulation is not wrong if we get warning. hope it helps teguh tf
Now Or Never!!! |
November 17, 2010, 07:04 |
Rep Power: 15 |
I think this message appeared because of mesh layering. Your cell size (aspect ratio) has changed because of the mesh motion. Then the cell size at layering location left the specified parameter range (set in the dynamic mesh / layering panel) and a new layer of hex-cell was inserted.
March 31, 2011, 03:57 |
jihyeong
Rep Power: 15 |
Thanks for your answear.~
I solved it but there's another problem...degassing BC... anyone knows about degassing BC?? |
April 6, 2013, 07:45 |
wang
Rep Power: 12 |
hello,I encounter the same problem as you ("Multiple subdivision required on zone 13"),could you tell me the method you solve the problem ,thank you !
November 17, 2021, 05:32 |
Zahra dastyar
Hi, I faced the same problem, the solution is defining a time step according to mesh speed and mesh size, for me the velocity was 1mm/s and the mesh size was 0.5mm by defining t=0.5 I got error but by t=0.25 it become okay.
July 15, 2023, 07:48 |
Rep Power: 6 |
I faced this problem when using the dynamic mesh, and I found it involved with the "cell height" (in dynamic mesh zones---mehsing options), when the height it too small, the warning popped up, once I had increased the height value, it disappeared.
Hope this may help users who encountered this problem. |
Display Modes | |
[Commercial meshers] Extension of fluentMeshToFoam internal cells and faces | gschaider | OpenFOAM Meshing & Mesh Conversion | 34 | January 2, 2011 11:01 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 07:59 |
IcoLagrangianFoam_problem | zhoubinwx | OpenFOAM Bugs | 2 | May 21, 2008 05:55 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
