Conjugate heat transer question - import from ICEM |
November 14, 2010, 16:40 |
Rep Power: 15 |
Dear all,
I am meshing a combustion chamber of a stirling engine mchp with ICEM and I am not sure about heat transfer through walls. So, I am meshing the fluid domain and the thin solid walls of my geometry with the TGrid tetra volume fill and ICEM does the meshing but although I assign different names for my solid volumes it puts all volume mesh under a single zone named, say, fluid. Fluent does the spliting to coupled walls allright but I need to ask: The fluid region and the solid regions are under the same zone name "int_fluid'' The fluid region is a mixture and the solid walls are steel. if i specify steel material in the BOCOs for the coupled walls containing the solid mesh will the mesh within be treated as steel or will it be treated as int_fluid = mixture? Thank you very much All the best |
Conjugate heat transfer with periodic boundaries | Suresh | FLUENT | 0 | February 23, 2009 09:51 |
best mesh generator for conjugate heat transfer? | phsieh2005 | Main CFD Forum | 1 | June 1, 2007 17:35 |
Heat flux question? | Mark | Main CFD Forum | 0 | February 13, 2004 09:03 |
conjugate heat transfer question | Kirill | CFX | 0 | January 10, 2003 04:50 |
Conjugate Heat/ thermal elastic ? | Jeff Perry | Main CFD Forum | 7 | June 16, 2001 05:00 |
