Conjugate heat transer question - import from ICEM
Old   November 14, 2010, 16:40
Default Conjugate heat transer question - import from ICEM
Catthan is on a distinguished road
Dear all,
I am meshing a combustion chamber of a stirling engine mchp with ICEM and I am not sure about heat transfer through walls.
So, I am meshing the fluid domain and the thin solid walls of my geometry with the TGrid tetra volume fill and ICEM does the meshing but although I assign different names for my solid volumes it puts all volume mesh under a single zone named, say, fluid.
Fluent does the spliting to coupled walls allright but I need to ask:
The fluid region and the solid regions are under the same zone name "int_fluid''
The fluid region is a mixture and the solid walls are steel.
if i specify steel material in the BOCOs for the coupled walls containing the solid mesh will the mesh within be treated as steel or will it be treated as int_fluid = mixture?
Thank you very much
All the best
Catthan is offline   Reply With Quote
Conjugate heat transfer with periodic boundaries Suresh FLUENT 0 February 23, 2009 09:51
best mesh generator for conjugate heat transfer? phsieh2005 Main CFD Forum 1 June 1, 2007 17:35
Heat flux question? Mark Main CFD Forum 0 February 13, 2004 09:03
conjugate heat transfer question Kirill CFX 0 January 10, 2003 04:50
Conjugate Heat/ thermal elastic ? Jeff Perry Main CFD Forum 7 June 16, 2001 05:00
