how to define two inlet boundary condition at the different time |
December 13, 2010, 02:43 |
ekkapong
Rep Power: 15 |
Dear all
pleas give me your suggestion about defining the two boundary condition at the different time for simulation heat transfer: first time= 0-15s use temperature = 150C, and then time= 15-30s use 91C . the output that I want to look are the outlet temperature of each inlet boundary condition. |
December 13, 2010, 04:44 |
Bernhard
Rep Power: 21 |
You can easily to this by means of a UDF. You can take a look in the UDF Manual, and use the DEFINE_PROFILE subroutine, in which you can base the value on the time. Good luck!
December 13, 2010, 18:40 |
Real Name :)
Rep Power: 16 |
See a very recent post for examples on how to do (simple) time-varying inlets:
http://www.cfd-online.com/Forums/flu...tml#post287097 Many basic problems like this can be solved by performing a quick search of the forum first. ComputerGuy |
Pressure Inlet Boundary Condition | Prasad | FLUENT | 6 | April 9, 2013 21:32 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
How to use a solution as an inlet boundary condition in another problem in fluent | geryes | FLUENT | 0 | February 25, 2010 16:32 |
Doubt in Inlet Pressure Boundary Condition | Sumitha | FLUENT | 3 | October 20, 2008 03:19 |
How to define the boundary condition | Merkle | FLUENT | 0 | December 1, 2000 04:01 |
