k residual goes up after temperature limitation warning???
Old   November 24, 2010, 17:48
Default k residual goes up after temperature limitation warning???
Catthan is on a distinguished road
Dear all,
I am modelling the combustion of methane-air in a stirling engine burner and after, say, 65 iterations and while all residuals decrease i get the temperature limitation (limited to 1K) warning and once I get it the k residual starts to increase (while all the rest keep going down).
At the moment the warning is restricted to 1 to 3 cells.
What I am using is the species transport with no reactions yet activated and the realizable k-ε turbulence model.
The solution is steady state.
I can tell that solution is at an early stage by a velocity monitor in my outlet which has not yet stabilised.
I understand it might be too early to worry but I think whatever is wrong has started affecting other cells
I am using a very fine tetra mesh with prism layers on the walls.
my bocos are:
mass flow inlet for my air and gas inlets with turbulence specification set to intensity and ratio - default values of 10% for both
outflow for my exhaust
coupled walls for components inside the burner where I must later compute conjugate heat transfer
0 heat flux for all other walls (e. g. the base of the burner)
I am running this huge case on a super computer facility and I am a bit pressed in time so any suggestions would be most appreciated
All the best
Catthan is offline   Reply With Quote
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
