May 20, 2004, 09:24 |
porous media resistance coefficients
hi all,
iam analysing an airfilter.(porousmedium).for the medium,i calculated resistance coefficients .the permeability given 24 CFM, that i converted into 8584e10 1/sq.meter for viscous coeff.problem is 3D and flow is in x direction. my questions, is my coeff. value is reasonable?. i gave resistance co efficients only in x direction,should i give in other directions? if i need to give,can i use the same value ? thanks for any suggestions. regards Thiyaga. |
May 20, 2004, 12:20 |
Re: porous media resistance coefficients
Your permeability is not unreasonable for a fairly restrictive filter. If you have x-direction flow only, you should can specify the y and z direction permeabilities to an order of magnitude or two higher than your x-direction value.
May 21, 2004, 00:08 |
thank you. as you said, the permeability values in y&z are higher than the value of X, the resistance coefficients in y&z should be lower than the value in x direction, is it so?. what about inertial coefficient, the same way can be used?. looking forward to your suggestion.... regards Thiyaga.
May 24, 2004, 11:48 |
The permeability inputs to FLUENT should be larger in the y and z directions. This is because the FLUENT input is actually the inverse of permeability. You can also do the same with IRF.
June 21, 2011, 18:07 |
zohreh
Rep Power: 15 |
I want to model a micro filter, This filter (membrane) is rectangular (10×5 cm) with the thickness 12e-5. so,I calculate this parameters from Ergun equation which D=1e-6, because of the Micro filter type. is this assumption true??
i think this is very thin filter so there in not flow through in the membrane, in this situation is inertial coefficieant higher in Y direction? or not?when i set y-direction inertial coefficient higher than x-direction got better answer! is this resonable? I am looking forward to hearing from you. Sincerely yours |
October 27, 2011, 06:24 |
regarding porous medium
#6 | |
vittal
Rep Power: 14 |
Sir,
I am modelling porous medium. I know velocity=5.6m/s pressure=5690 pa discrete phase model thicknes of porous medium=0.15mm porosity =0.95 now how to calculate K and c2? Quote:
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 7 | May 14, 2020 16:34 |
Viscous resistance coefficients in porous medium | fpingqian | FLUENT | 50 | June 26, 2019 01:55 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
viscous resistance coefficients in Porous media | choyong | FLUENT | 9 | December 15, 2014 20:01 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
